February 28, 2023 at 9:27 pm
Mathis Allen
SubscriberI am looking to do a parametric analysis in Maxwell 2D. However, the number of points I want to run ends being 493. My setup only allows 10 points being run until the system crashes. Is there any way I can get Maxwell to run a certain number of points, export the data into Excel, delete that data to clear space, and continue by itself?
March 8, 2023 at 12:54 am
NKC
Forum ModeratorHi Mathis,
Your issue seems to be with the disk space. See if you can increase the disc space.
You may be able to do the required automation through scripting.
Please refer to the scripting section in Maxwell help.
Navya
August 10, 2023 at 8:34 am
Allenroberson999
SubscriberIs there any way I can get Maxwell to run a certain number of points, export the data into Excel, delete that data to clear space, and continue by itself?
- The topic ‘Automatically Split Parametric’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4618
1530
1386
1209
