September 28, 2023 at 6:46 am
audrey.piccini
SubscriberDear all,
I am using an Autodyn subroutine for a project and the simulation stops at cycle 99,999, see the image below.
What I do not understand is that the criteria that could limit the number of cycles is much more important than 100,000:
- Controls > Wrapup Criteria: >100,000;
- Output > Interrupt: End cycle = 100,000,000;
- Output > Call EXEDIT: End cycle = 100,000,000;
In addition, the subroutine usrsub2.f90 calls the "WRAPUP" module but does not redefine it, so there is no arbitrary "NCYLIM" defined in the subroutine. Do you know where this limitation might come from?Thank you in advance for your help,
Audrey
September 28, 2023 at 12:41 pm
Erik Kostson
Ansys EmployeeHi
Can you post this in the Explicit forum where you might get more help.
/forum/forums/forum/discuss-simulation/ls-dyna/
All the best
Erik
- The topic ‘AUTODYN Subroutine – Cycle limit’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1220
1118
1015
