September 28, 2020 at 5:34 am
Centurion_2020
SubscriberHello,nI was trying to model explosion and obtained P(t) curve via Gauge point. Now, I would like to get impulse result for that P(t) curve. In the History menu when you make P(t) curve there is an option INTEGRATE bellow. I guess it is here for impulse calculation, but I usually get bad results. How to get accurate reading of impulse for particular P(t) curve since when I do INTEGRATE, I get another curve?n -
September 28, 2020 at 7:11 am
September 28, 2020 at 6:01 pm
Missy Ji
Ansys Employee You can create the pressure impulse by clicking on the box Integrate after plotting the time history of pressure at a gauge point. What do you mean bad results?n -
September 28, 2020 at 10:01 pm
Chris Quan
Ansys EmployeeYou need to subtract atmospheric pressure from the pressure calculated before calculating the impulsen -
September 29, 2020 at 6:11 am
Centurion_2020
Subscribermji, please look at the upper two images. Lower image is integrated curve of the P(t). What exactly is impulse values on this curve, how can I read it exactly?.cxquan, how can I subtract atmospheric pressure in Autodyn on P(t) curve before calculating the impulse?.n -
September 29, 2020 at 10:21 pm
Chris Quan
Ansys EmployeeTo get over-pressure by subtracting atmospheric pressure from the calculated pressure, you can either add atmospheric pressure to P-shift in the EOS or click on Write Text Output to export the data to Excel. Then in Excel to subtract the atm.n -
September 30, 2020 at 8:13 am
Centurion_2020
SubscriberThanks man, this was very helpful. nI was wondering if you know why there is a second peak behind initial peak over-pressure in autodyn? I am running free air-burst simulation, no reflection of any kind. Can this be solved by some initial setup before running simulation?nI am uploading an image of one example.n
n
Viewing 6 reply threads
- The topic ‘Autodyn impulse’ is closed to new replies.
1891
1419
