May 9, 2024 at 2:23 pm
ahmed.taher
SubscriberHello,
I don't know why, but AutoDyn GUI closes during a running simuation all of a sudden, without even displaying an error or warning message. I am stuck and don't know how to fix this issue, I don't even know what causes that
Any help?
Thanks in advance.
May 10, 2024 at 8:35 pm
Chris Quan
Ansys EmployeeYou can open the ident.log file in the directory of the results files using any text editor to see if there is any error message. If yes, you need to modifiy your model setup accordingly.
Then, you can start Autodyn GUI, open the last saved restart file (ident.ad), click on Run button to restart the analysis and continue the simulation.
Finally, if you were running the model with parallel processing using many number of cores, you may reduce the number of cores in restart analysis if the model size is not very large.Â
- The topic ‘AutoDyn GUI closes during simulation SUDDENLY’ is closed to new replies.
