3D Design
3D Design
Auto Skin Keep Faces from Solid Body
    • jmoore
      I'm trying to use Auto Skin selecting the original solid body to keep the facets that match the faces of the origianl solid body following the instructions here: Creating the CAD Geometry
      However, when I run the tool, it doesn't match the faces and I'm left with a geometry like this:
      Any suggestions on how to make this behave more like the example?
    • Atharv Joshi
      Hi Jmoore,
      If you are using Autoskin the result should be patch body (CAD) and not a faceted body.
      Do you see any error message after the Auto-skin operation? The image seems like a result of ShrinkWrap Tool.
      Regards
      Atharv
    • jdmoore2
      Hi Atharv,
      You are correct. I submitted the wrong picture. Here is a better example:
      I would expect it to look more like this simplified example part I was able to get working:
