November 12, 2023 at 5:33 pm
Mariah Ha
SubscriberHi,Â
I am running a simulation in FDTD and would like to ensure that the auto-shutoff level is below 1e-05, as recommended in the tutorials. However, I obtained this graph. The auto-shutoff level suddenly increases at some point in the simulation after reaching 1e-04. Is there any explanation for this issue? I could not find a reason for the autoshutoff to not continue decreasing until 1e-05.Â
November 15, 2023 at 8:19 am
Niki Papachristou
Forum ModeratorHi Mariah,
Thank you for reaching out to us! Have you changed any of your simulation parameters (simulation time, auto-shut off level) to see if you get any different behavior? You might find this post helpful: Questions Regarding Autoshutoff level
Kind Regards,
Niki Â
November 15, 2023 at 8:27 am
Mariah Ha
SubscriberThank you for the reply. Yes I changed the simulation time but kept the autoshut off level the same 1e-05. When I set the simulation time to 2000 ps the autoshutoff is around 4e-05, so I increased the simulation time to 3000ps to see what is the exact time the simulation will terminate , and thought I could record something around 2400ps . However, this did not happen, and I noticed that the shutoff level showed that strange increase at some point of the simulation, after 2000ps. Does it mean that the simulation time I set is too long? But why it did not just shut when the simulation is around 2400ps or so ?Â
November 15, 2023 at 9:06 am
Niki Papachristou
Thank you for coming back, can you please confirm that after the complition of the simulation the auto shut off status is 2? I am affraid that you have been looking the progress of the auto shut off level and not the full completion. I would suggest to check the graph after the completion:
If this drops from 1 to 0 then the simulation reached the autoshut off level as expected.
Niki
November 15, 2023 at 10:12 am
Mariah Ha
SubscriberHi, yes I have been looking at the progress of the autoshutoff level. Yes the status is 2 and it is the required graph. Thank you very much.
- The topic ‘Auto-shutoff level in FDTD incresed?’ is closed to new replies.
4618
1530
1386
1210
