November 12, 2024 at 8:01 am
zwernjayden
SubscriberIs fluent able to simulate the atomization due to collision of two streams using dpm? Or only collision and momentum transfer due to collisions, and natural breakup due to the continous phase
November 12, 2024 at 11:30 am
Forum ModeratorIt should work. But both streams must be the same DPM material. The size and force effects can come from DPM collision or flow field. But check how the model works too: there are some assumptions that can make the effect somewhat mesh dependent.
November 12, 2024 at 9:04 pm
zwernjayden
SubscriberCan the streams be the same multicomponent template but the mass fractions defined in the injections are different?
1890
1414
1303
