March 4, 2022 at 7:01 am
19yuuki91
SubscriberHi everyone
I am currently modeling a wall in Ansys 19.2 academic version, and I wanted to ask for suggestions regarding material assignment with APLD commands.
In short, I am using the microplane model to represent the brick properties. As far as I know, you can only define the microplane model using APLD commands. I've done so in a smaller scale, by inserting a commands under each part and defining the model and it worked fine. However, in the case of the wall, given the number of bricks, I was wondering if there was an alternative way to define the model for each individual brick. In other words, if I want to use the microplane model in my wall, do I have to insert the commands under each brick part? or, is there another way to assing the command to all brick parts at once?
Thank you very much for your help.
Yuuki
March 4, 2022 at 2:59 pmGovindan Nagappan
Ansys EmployeeYou can create a named selection that has all the bodies with same material
Then select the named selection in the command script and assign a material using APDL commands. You can insert the commands under analysis branch (static, modal etc)
Example:
/prep7
cmsel,s,named_selection_name !use named selection name from your model
emodif,all,mat,material_number !use the appropriate material number. You can define material also if needed
allsel
/solu
March 30, 2022 at 5:36 am19yuuki91
I am sorry for the late response.
Thank you very much for your answer, I did as you told me and worked just fine.
Best regards
Viewing 2 reply threads- The topic ‘Assigning materials to several parts with apdl commands’ is closed to new replies.
