November 16, 2020 at 8:31 pm
ashishchouhan
SubscriberHello, I am trying to work on a problem that needs a heat generation term on the common surfaces of the shown blocks. Fluent only allows me to input separate heat terms on the two surfaces that touch each other. Any way to make the two surfaces behave as one and assign one generation term? Thank you for your help!
November 17, 2020 at 1:49 pmkarthik.remella
AdministratorHello, nFluent should automatically create a wall - wall-shadow condition where you have two different cell zones sharing a common wall. This should be the behavior with you create a conformal mesh. You should be able to apply the 'Heat Flux' condition here. Please see the screenshot. n
nI hope this answers your question.nThank you.nKarthik n
Viewing 1 reply thread- The topic ‘Assigning a heat generation term to common surface of two adjacent blocks’ is closed to new replies.
