Electronics
Electronics
assign a different magnet magnetization at each node
    • Noemi Novello
      Is there a way to assign a different magnetization value in a permanent magnet by importing the values at each node?
    • NKC
      Hi Noemi Novello,
      What are you referring to as nodes here?
      Suppose your interest is to assign different magnetic properties and directions in a single magnet. You can model the magnet as individual small magnets and then can assign the required magnetic properties and magnetization directions to each.
      Navya
    • Noemi Novello
      What I'm trying to do is to magnetize/demagnetize some magnets in a project and then insert this magnet (and their magnetization, which is not uniform) into another project.
      I'm not familiar with ansys, but I know for sure that this can be done in other FE software like Flux Altair or Opera Dassault Systemes.
  • The topic ‘assign a different magnet magnetization at each node’ is closed to new replies.
