Aqwa:setting the waterline?
    • lshangguan2020
      Hello, I plan to use ANSYS AQWA to calculate a floating platform with a mooring system. I have a question regarding setting the waterline (i.e., the design displaced volume): should the effect of mooring tension be considered, and should the waterline be set based on the position without mooring forces or under the effect of mooring forces?
Viewing 0 reply threads
