November 15, 2024 at 6:21 am
1262968043
SubscriberHi!
i met a problem when i used aqwa user_force through Python in Workbench. I strictly follow the process in the v232\aqwa\utils\ExternalForceCalculation\README, however, whether I start the time response from Workbanech or classic AQWA, the following problem occurs: PROBLEMUSINGREMOTEUSERFORCE.CONNECTIONTIMEOUT.ISSERVERRUNNING?. What is the reason? Thank you very much!
November 19, 2024 at 12:59 pm
Ingrid M
Ansys EmployeeÂ
Hello, you don’t seem to have the port number generated (file with a cfg extension).
In a command window, could you try to start the server manually first: [your path to python]\python.exe  AqwaSocketForceExample.py? At least you can see if this part works. There is a python version available in your ansys install under the commonfile folder.
When you run it from Aqwa workbench, you will need to ensure that the command you enter is correct and can start off the server correctly.
I hope this helps.Â
December 9, 2024 at 2:34 am
1262968043
SubscriberIt works now,thank you very much
5859
