March 13, 2024 at 9:46 am
NVN NAMMA
SubscriberI have been running a simple simulation of a spar platyform, which was showing displaced volume twice the actual volume. why this error coming, meta centric height and other values are same. I have drawn a circle extruded, thinned and sliced.Â
March 15, 2024 at 1:23 pm
Shuangxing Du
Ansys EmployeePlease check your geometry:
(1) only external hull surfaces are defined;
(2) the normal directions of the surfaces points towards the external water.
(3) the spart platform is at the correct position related to the still water level.
May 12, 2024 at 12:37 pm
NVN NAMMA
Subscriberthe problem were sorted out
- The topic ‘AQWA, The displaced volume is twice the actual volume’ is closed to new replies.
1307
