November 29, 2024 at 4:00 pm
Gabriele
SubscriberHello,
I have a question regarding the modelling in presence of internal fluid tanks in AQWA...
When there are only solid masses, my understanding is that the reference point for hydrodynamics (addedd masses, damping, generalized forces) is the global centre of gravity (please correct me if I'm wrong).
However, in case there are fluid tanks in the model, I could not find specific information on which point is used as reference.Â
The Hydrostatic summary reports information on the position of the "Structure Center of Gravty (CoG)" (only solid masses) and of the "Combined Center of Gravty (CoG)" (fluids + solid masses).Â
Which one, if any, of the two is used as reference? The "Combined" one?
If none of the two is used, then which point is used?
Thanks,
Gabriele
December 2, 2024 at 11:39 am
Shuangxing Du
Ansys EmployeeWhen there are internal tanks defined with a structure, the motions and total added mass/damping/hydrostatic stiffness matrices and generalised forces are with respect to the rigid body motions at the combined center of COG, which is defined by Equation (3.25) in 3.4.1. Local Internal Tank Axes and Combined COG.Â
December 2, 2024 at 2:39 pm
Gabriele
SubscriberDear Shuangxing Du,
thank you for the clarification!
Gabriele
December 2, 2024 at 3:35 pm
Shuangxing Du
Ansys EmployeeHi Gabriele,
You are welcome.
Shuangxing
5964
1307
