March 26, 2024 at 6:40 am
March 27, 2024 at 12:41 pm
Shuangxing Du
Ansys EmployeeThe buoy can be defined by a hydrodynamic diffraction structure in the Hydrodynamic Diffraction analysis, and the joint(s) can be defined in the Hydrodynamic Response analysis.
March 28, 2024 at 5:13 am
r.abbasi
SubscriberThanks for your response.
But maybe I have not asked my question clearly. I want to know how can I get this Graphic Picture of the model from AQWA.
March 28, 2024 at 9:13 am
Shuangxing Du
Ansys EmployeeIf you define this model in Aqwa-Workbench, the model can be displayed in the Graphical window in WorkbenchÂ
If your model is created by SpaceClaim, some model dimensions could be drawed. Â
If you run Aqwa solver only for the time domain/equilibrium/frequency statistic analysis. The model can be displayed in Ags. To do it, please double click on (your Ansys installation folder)\aqwa\bin\winx64\Ags.exe -> File (to import the .res file of your analysis) -> Plots
- The topic ‘AQWA PIC output’ is closed to new replies.
5799
