AQWA Morison TUBE Elements on Cylinder
    • bengalili
      Hi.
      I want to conduct a hydrostatic analysis on a Cylinder from the sea surface to the sea depth.
      I need to get the force and moment exherted on the cylinder.
      1. It works but in the LIS file I get very low (almost Zero) moment and force.
      2. I also want to make sure that the moment is calculated arround the sea floor.
      3. how do I control the drag coefficient and added mass coefficient?
      Appriciate the help.
      example:
      Diameter - 1m
      sea depth - 5m
      Wave period - 10 sec
      JOB 0001  LINE
      TITLE               CYLINDER MODEL
      OPTIONS LDOP GOON REST END
      RESTART   1  3
          01    COOR
          01   1                 0.0       0.0       0.0
          01   2                -0.5       0.0       0.0
          01   3                -1.0       0.0       0.0
          01   4                -1.5       0.0       0.0
          01   5                -2.0       0.0       0.0
          01   6                -2.5       0.0       0.0
          01   7                -3.0       0.0       0.0
          01   8                -3.5       0.0       0.0
          01   9                -4.0       0.0       0.0
          01  10                -4.5       0.0       0.0
          01  11                -5.0       0.0       0.0
          01 999                 0.0       0.0      -5.0
       END01
          02    ELM1
          02TUBE          (1)(1)(2)(1)(1)
          02TUBE          (1)(2)(3)(1)(1)
          02TUBE          (1)(3)(4)(1)(1)
          02TUBE          (1)(4)(5)(1)(1)
          02TUBE          (1)(5)(6)(1)(1)
          02TUBE          (1)(6)(7)(1)(1)
          02TUBE          (1)(7)(8)(1)(1)
          02TUBE          (1)(8)(9)(1)(1)
          02TUBE          (1)(9)(10)(1)(1)
          02TUBE          (1)(10)(11)(1)(1)
       END02
          02    FINI
          03    MATE
          03             1     7800
       END03
          04    GEOM
          04TUBE         1       1.0       0.1         0.0
       END04
          05    GLOB
          05DPTH     5.0
          05DENS    1025.0
          05ACCG     9.806
       END05
          06    FDR1
          06PERD    1    1      10.0
          06DIRN    1    3    -180.0       0.0     180.0
       END06
          07    WFS1
       END07
          08    NONE
      LIS OUTPUT:
    • Shuangxing Du
      In your nodal coordinate defintion (Node#1 ~ Node#11) and the tube element definition,  the tubes' axial axis is on the mean water surface and  along x-direction.
      The force and moment are output with respect to the COG of the structure, i.e. (Xg, Yg, Zg).  If you want the moment to be output with respect to another reference point, i.e. (Xr, Yr, Zr),  please manually do the calculation with the additional cross product term:
      (Mrx, Mry, Mrz) = (Mx, My, Mz) + (Xr -Xg, Yr-Yg, Zr-Zg) x (Fx, Fy, Fz)
      where (Mx, My, Mz) is the moment with respect to COG, (Fx, Fy, Fz) is the force with the respect to COG.
      The translational drag and added mass coefficients can be input by CONT data record, see below and see 8.3. Geometric Property Data Record (ansys.com)
