TAGGED: ansys-aqwa, ansys-cfx, aqwa, aqwa-errors, cfx, hydrodynamic-response
September 25, 2023 at 1:15 pm
Kursat Guner
SubscriberHello,
I am new to Ansys AQWA. I have tried to solve this problem on both Ansys AQWA 2021 R1-R2 and AQWA 2023 R1.
It says E.RES does not exist but there is a .RES file.
As you see here, module already created. Its path is,
..\Ansys\275_Deneme\275_Deneme_files\dp0\AQW\AQW\AQ\AnalysisÂ
The path is where the project is saved on desktop.
And I have this things on the panel.
Thank you anyway.
September 29, 2023 at 1:23 pm
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: Warning: No applicable Aqwa Restart File could be found (ansys.com)
Ashish Kumar
October 10, 2023 at 7:57 am
Mike Pettit
Ansys EmployeeHello,
Please can you navigate to 275_Deneme_files\dp0\AQW-1\AQW\AQ\Analysis, open Equilibrium.dat, then confirm the path shown on the RESTART line:
Yours should refer to the local path to the Hydrodynamic Diffraction system in your project, i.e. ...\275_Deneme_files\dp0\AQW\AQW\AQ\Analysis\Analysis.
If it does not, are there any special characters in the folder path?
Mike
October 16, 2023 at 11:15 am
Kursat Guner
SubscriberHello all,
I have solved the problem. It was about Mike asked, there was a "space" in my working folder. I changed it and it is working well.
Thank you.
- The topic ‘AQWA Module Hydrodynamic Response Problem (FILE DOES NOT EXIST E.RES)’ is closed to new replies.
4607
1510
1386
1209
