September 19, 2024 at 12:31 pm
Wei.Shao
Subscriberwhen I run aqwa-line with drag elements (add a irriegular wave to consider the linearised morrison drag), i got the following errror:
**** SYSTEM ERROR **** LINFER:DRAG LINEARISATION FAILED TO CONVERGE
May I ask how to solve this issue, any suggestions? thank you!
September 24, 2024 at 11:26 am
Shuangxing Du
Ansys EmployeePlease check if the drag coeeficients of Morison elements (tube, disc, slender tube) and the irregular wave are defined reasonably.
September 30, 2024 at 3:56 pm
Wei.Shao
SubscriberThank you for your reply. What i found is if I increase the drag coefficeint, it can converge.Â
