Aqwa Hydrodynamic Response Error
    • rx20729
      I am trying to run some stability analysis within Ansys Hydrodynamic Response on a vessel that I have modelled. However, I am running into the following error:
      The model is made up of three interacting structures and I am also using some non-linear catenary mooring lines that are connected between connection points on the structures and fixed points on the seabed. The error does not occur when I run stability analysis on the main vessel, however, when I add the other two structures and the mooring lines to the model, I receive this error message and also the whole structure moves significantly.
      Any ideas as to what could be causing this error message will be greatly appreciated.
      Thank you.
    • Shuangxing Du
      You could set Maximum Error in Equilibrium to be Manual Definition, and adjust the Maximum Positional Error
      • rx20729
        Thank you for your reply.
        I have tried this and I am still getting the error.
        I have also manually defined the movement limitations per iteration and the error is still occuring.
    • Shuangxing Du
      Can you please show your model?
  • The topic ‘Aqwa Hydrodynamic Response Error’ is closed to new replies.
