September 25, 2018 at 6:43 pm
soloviev
SubscriberI have been told that AQWA does not work on Linux clusters. However, on a Windows cluster, Aqwa models can be solved on a single node only since Aqwa is not MPI aware. Could you clarify what is meant by a node in this statement?
Also, does AQWA work on HPC on a workstation?
Thank you,
Alex
September 25, 2018 at 8:57 pm
pgl
Ansys EmployeeHi Alex,Â
See here for our supported platforms by application. AQWA is MS Windows only.Â
Single "node" in this context I believe means a single device (computer) within the cluster. A single node may have one or more CPU cores.
Our AQWA online doc has a section called "4.4.1. Setting Aqwa Parallel Processing Options" - This explains that AQWA can make use of multiple CPU cores. So yes, AQWA can take advantage of HPC.Â
September 25, 2018 at 9:29 pm
soloviev
SubscriberThank you for this information.Â
Best regards,
Alex
September 25, 2018 at 10:53 pm
pgl
Ansys EmployeeMy pleasure. So glad this was useful Alex:-)Â
- The topic ‘AQWA HPC question’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1241
1118
1015
