January 13, 2022 at 12:47 am
Jezza
SubscriberHi,
I am currently getting the below error messages when trying to add a result plot to my hydrodynamic analysis solution.
January 13, 2022 at 7:41 amMike Pettit
Ansys EmployeeHi Jeremy This is a known issue which has started affecting all Aqwa releases on Jan 1st 2022. This prevents Aqwa Workbench from accessing Hydrodynamic Diffraction and frequency statistical Hydrodynamic Response graphs (also AqwaGS, but not AqwaReader as you have discovered).
Please see the workaround suggested here (works for Release 2020 R1 onwards): /forum/discussion/35144/plt-file-when-using-workbench-aqwa#latest
Please let me know if you have any issue using this approach. We will be providing a patch as soon as possible.
Mike
January 13, 2022 at 9:00 pmJezza
SubscriberThank you Mike, this has resolved my issue for now.
April 23, 2022 at 8:17 pmAngelyr
SubscriberHi all,
I am using Ansys 19 so the solution proposed above does not work for me.
I have tried changing the computer date manually to the year 2021 and it works.
I hope this "solution" will help someone.
Regards
August 22, 2023 at 2:23 amViewing 4 reply threads- The topic ‘Aqwa error during diffraction analysis’ is closed to new replies.
5824
