TAGGED: aqwa, co-simulation, fmi, FMU, rigid-dynamics
March 13, 2023 at 8:25 pm
xinyuan.shao
SubscriberHi!
I want to use aqwa and rigid dynamics to simulate a wave energy converter. I wonder if there are some tutorials about this co-simulation available? The description in aqwa is too concise. Thank you!
Xinyuan
March 15, 2023 at 5:01 pm
Mike Pettit
Ansys EmployeeHello,
I'm afraid the training material for the Aqwa-Rigid Dynamics cosimulation has not been published yet, however the online documentation provides a description. This is contained in Section 8.3 of the Aqwa User's Manual, which you should be able to access from the Aqwa Workbench editor by clicking Help > Workbench User's Manual.
Mike
March 16, 2023 at 7:41 am
xinyuan.shao
SubscriberHi,
Thank you. Is there any training material for co-simulation under preparation? If so, when it will be available?
Xinyuan
March 16, 2023 at 4:17 pm
Mike Pettit
Ansys EmployeeHi Xinyuan,
The training material exists in draft state, so it shouldn't be too long before it is published... but I can't give you an exact date, I'm afraid.
If you have a customer account, you could try creating a Service Request to ask for the material directly from the Aqwa development team.
Cheers, Mike
August 16, 2023 at 7:45 am
mohsen ab.1999
SubscriberHi
i also use aqwa co simulation for simulating floating offshore wind turbine and in the aqwa co simulation setup in ansys rigid dynamic module i have a big problem with uploading the Aero Dyn primary input file and inflow wind input file , it does not work and in extension log file some erorre appear like this :
AqwaCosimulation: Inadequate blade data files (ADBlFile) given in the AeroDyn primary input file (C:\Users\fatemeh.km\Desktop\AeroDyn primary input file.txt)
AqwaCosimulation: Failed to prepare the AeroDyn marker data.......can you send a Aero Dyn primary input file sample for me ?
this is my Email :abnmohaen@gmail.com
August 24, 2023 at 1:52 pm
Mike Pettit
Unfortunately as an Ansys employee I am not able to share anything with you through this forum, hopefully someone else can help you out with this. However, I can suggest that your AeroDyn input file may be missing some key lines like:
======  Rotor/Blade Properties  ========================
True      UseBlCm       - Include aerodynamic pitching moment in calculations?  (flag)
"BladeData.dat" Â Â ADBlFile(1) Â Â Â Â - Name of file containing distributed aerodynamic properties for Blade #1 (-)
"BladeData.dat" Â Â ADBlFile(2) Â Â Â Â - Name of file containing distributed aerodynamic properties for Blade #2 (-) [unused if NumBl < 2]
"BladeData.dat" Â Â ADBlFile(3) Â Â Â Â - Name of file containing distributed aerodynamic properties for Blade #3 (-) [unused if NumBl < 3]The number of entries should match the number of blades (3 in this example). I hope this helps.
Mike
- The topic ‘aqwa and rigid dynamic co-simulation’ is closed to new replies.
4618
1535
1386
1210
