AQWA, Actual and RAO based acceleration and response
    • NVN NAMMA
      Hi
      I have simulated a hollow cylinder for hydrodynamic analysis. I did physical experiments on the same mode. calculated viscous damoing and gave as an additional damping in aqwa. when i tried to validate the e4xperimental and numerical results the trend is seen with actual acceleration and the magnitude is matching with rao based acceleration. how to handle this .
      Also
      1. Acceleration is non linear but in the displacement plot the forms regular. Why is it so?
      2. acceleration
      3.
    • ashish.khemka
      I see you posted the same query here: AQWA, Actual and RAO based acceleration and response
      I will close this one.
      Ashish Khemka
  • The topic ‘AQWA, Actual and RAO based acceleration and response’ is closed to new replies.
