May 30, 2024 at 4:55 pm
NVN NAMMA
SubscriberHiÂ
I have simulated a hollow cylinder for hydrodynamic analysis. I did physical experiments on the same model. calculated viscous damping and gave as an additional damping in aqwa. when i tried to validate the experimental and numerical results, the trend is seen with actual acceleration and the magnitude is matching with rao based acceleration. how to handle this . Any explanation will be highly useful.
2. when i calculated displacement from acceleration using fft code it was not matching with the aqwa displacements.
3. how aqwa calculates actual response?
4. how displacements and accelerations are related in aqwa?
June 4, 2024 at 10:00 am
Shuangxing Du
Ansys Employee(1) Please see Aqwa theory manual, Section 13.5.3 Motions at Drift and Wave Frequency, the RAO based motion, velocity and acceleration are given by
in which the irregular waves are represented byÂ
(2) For actual acceleration calculation, the predictor-corrector algorithm is employed, and the raditation forces is caluclated by the impulse function convolution,
the velocity and position is then calculated by
June 5, 2024 at 10:18 am
NVN NAMMA
SubscriberThank you so much sxdu for the reply.
 I saw the documentation on RAO based and actual acceleration and motion parameters.
What is the major difference in the RAO based and actual acceleration? .
For an experimental validation which one should i consider? I had kept a sensor on the top of the model with moonpool. I used nodal displacement after creating a connection point and fixed point on the top.. The RAO based values are matching with the magnitude and actual shows the trend.
2. For a regular wave analysis in aqwa naut, why small irregularities are seen in the result'
This is from the user manual. Can i have more explanation on the high lighted part
NB. model is in moored condition with cables
- The topic ‘AQWA, Actual and RAO based acceleration and response’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4512
1494
1386
1209
