Electronics
Electronics
Applying rotor skew
    • mi264
      Hello all,
      I have designed a PMSM in ansys maxwell. I want to apply skew in rotor and observe the change of characteristics. My question is:
      how can I apply skew in the rotor or magnet in the maxwell?
      Thank you
    • NKC
      Follow the below steps for setting a skew model design in Maxwell 2D.
      click Maxwell 2D > Design settings
      Select model settings > Use Skew Model.
      Refer to Maxwell Help > SKew Model setup section for more details
      Navya
    • mi264
      Thank you Navya
    • NathanEmery1
      Hi Navya,Thank you for this post, I have also been using the Skew model for a PMSM in Maxwell. nIs there a way to apply a V-skew technique where the segment settings are not distributed from + to - degrees. nFor example if I want to apply a V-skew with +2.5 deg, 0 deg and +2.5 deg segments is this possible using the ansys Skew settings? nnPlease let me know. nThank you, Nathann
      • DELI
        V-shape skew type is avalialbe in 2023R2.
    • NKC
      nYour question is being answered in the below post.n/forum/discussion/comment/104550#Comment_104550n
Viewing 4 reply threads
  • The topic ‘Applying rotor skew’ is closed to new replies.
