November 11, 2019 at 7:05 pm
tumulpurwar
SubscriberCan anyone tell me procedure for applying pretension to line element(..in my case it is truss element(LINK 180). -
November 12, 2019 at 3:11 am
peteroznewman
SubscriberIf you are using Mechanical Workbench, you must have more than one element along the Line Body. Use a Sizing Mesh Control to set the Number of Divisions to 2. Then use a Bolt Pretension load and turn on Large Deflection under the Analysis Settings.
December 15, 2019 at 12:44 pm
tumulpurwar
SubscriberHello...I would like to know...how much pretension I have to apply for my rigs(steel ropes)...to make my mast assembly stable in crazy windy weather.....I just want know general answer...in such cases how to get the pre tension load values..?
I am attaching photo to understand the situation more better -
December 15, 2019 at 2:23 pm
peteroznewman
SubscriberWhen the wires have zero pre-tension, the mast will move some amount for a given wind speed.
When the wires have some pre-tension, the mast will move less in the same given winds speed.
As the pre-tension is increased, the mast will move less and less.
You have to decide how much mast movement is acceptable.
However, if you increase the pre-tension too much, the mast will buckle.
You want to analyze how close to buckling the mast is for the pre-tension and the wind.
December 15, 2019 at 5:13 pm
tumulpurwar
Subscriberyes right, i want to know that(Â how close to buckling the mast is for the pre-tension and the wind)...may i know?...thankyou for such nice reply
December 15, 2019 at 11:57 pm
peteroznewman
SubscriberRead this section of ANSYS Help
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_buckling_analysis_type.html
- The topic ‘Applying pretension to line element (truss)(OR LINK 180)’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4102
1487
1318
1156
