July 2, 2023 at 1:31 am
Selawe97
SubscriberHi
I have a simple 2d square domain with heat flux at the bottom, when I activate the non-equilibrium thermal model in porose media in fluent, it creates a new solid zone coincides with the fluid zone, and as a result of that it creates new walls at the boundaries of the domain, for example, I will be having two walls at the bottom, one for fluid and a new one for the solid (porous zone) which mean two walls at the bottom boundary, the question is where should I apply heat flux, or in other words how I should apply heat flux at the bottom so the total heat flux be 4000 w/m^-2. to a fluid wall or solid porous wall or do I still need to do another step?
Thanks for helping -
July 3, 2023 at 2:20 pm
Forum ModeratorIt's not quite that simple. The two walls don't see one another, so you need to decide which wall to heat by how much.Â
July 4, 2023 at 8:22 am
Forum ModeratorAs a comment (and skirting the edge of where I can't say anything), which heat transfer mechanism do you think will dominate?Â
- The topic ‘Applying Boundary conditions for non-equilibrium thermal model in porous zo’ is closed to new replies.
