May 3, 2024 at 4:43 pm
alexandre.gomes
SubscriberDear all,
I am trying to simulate the alkali-aggregate reaction that results in a strain of the concrete mass.
First i performed a transient thermal analysis to determine the temperature of each node in each time step.
Then, using the temperature values in each node (in each time step) I calculated the correpondante strain values (using a python script).Â
Now i would like to apply those strains to the nodes in my FE model, for each node i would like to apply a strain value, for each time step.
I have read about the INISTATE command (successfully applied a constant strain value to the geometry) and i would like to ask if this would be a possible solution to my problem and how would it be implemented.
Thank you all.
May 6, 2024 at 10:32 am
ashish.khemka
Forum Moderator -
May 23, 2024 at 2:27 pm
alexandre.gomes
SubscriberHi,
Thank you for your comment, it helped.
However i am still far away from solving my issue, is it possible to apply a different strain for each node in each load step? I have 5000 nodes and 960 loadsteps...
May 24, 2024 at 7:43 am
ashish.khemka
Forum ModeratorHi,
You can use nested do loops to select loadsteps and nodes per loadstep.
Ashish Khemka
- The topic ‘Applying a Strain using INISTATE command’ is closed to new replies.
