May 3, 2019 at 12:30 pm
TAPTAPTAP
SubscriberI've been searching for a solution for the convergence issue and I found one suggesting to "Apply the load slowly". What does this mean exactly? Does it mean I should add more Loadstep instead of 1? (like in the pictures below)
1. Apply force as constant
2. define loadstep to 10 and use tabular data to apply forces
If i understand correctly, applying the load slowly should mean ' add the number of loadstep to like 50 or 100 ' right?
May 3, 2019 at 3:13 pm
peteroznewman
SubscriberThat is one way to do it.
A better way is to set Automatic Time Stepping to On and define Initial Substeps to be a large number, like 10 or 100 and in some cases, the Minimum Substeps to also be a large number, but potentially smaller than the Initial. The Maximum Substeps just has to be an even larger number, but that doesn't force it to use that many, it is just an upper limit, whereas the Minimum Substeps is enforced.
May 3, 2019 at 3:27 pm
May 3, 2019 at 5:49 pm
peteroznewman
SubscriberThere are many, many discussions on convergence failure. Search and you will find them.
- The topic ‘apply the load slowly?’ is closed to new replies.
