April 3, 2024 at 3:56 pm
EYAGGELOS TSICHLAS
SubscriberHello. I am undergraduate student in the University of Western  Attica and I have installed the student Ansys program. I work this program in collaboration with the CFturbo program for my thesis. I have a problem about with the set up. Few days ago I run a project and my antivirus quarantined a file perl.exe and the run stopped. After this , I made new different project in new Workbench and I cannot do set up and run because the file perl.exe isn't found in the four envelopes which is written in the error. I am thinking to restore this file in these four points which are mentioned in the error. To do it ? I need your help. I want your advice please.Â
April 11, 2024 at 12:25 pm
George Karnos
Ansys EmployeeI would suggest to shut down your antivirus software and reinstall ANSYS Student by right-click on setup.exe and choosing: run as administrator.
Then in whatever antivirus software you are using, exclude the ANSYS Installation directory. -
April 11, 2024 at 2:58 pm
EYAGGELOS TSICHLAS
SubscriberThank you very much for your response. I have restore the file perl.exe and the ansys operates. When I finish the set up I will run it with disabled the antivirus.
- The topic ‘Application failed to connect’ is closed to new replies.
5929
1306
