May 29, 2020 at 7:16 pm
FMS20
SubscriberHello,
I am running Fluid flow (Fluent) in Ansys Student 2020 R1 and keep getting an 'Application failed to connect' message when trying to open 'Results'.
If I try the same procedure in Fluent Flow (CFX), I cant even access 'Setup,' and get the exact same result as in this thread:
/forum/forums/topic/cfx-application-failed-to-connect-1/
 with the exception that I am using the 2020 R1 version.
I have followed the steps outlined in that thread, and got the same ineffective results.
Is there anything else I can try?
May 29, 2020 at 8:23 pm
Hunter Wang
Ansys Employee Try to set an system environment variable QT_OPENGL=desktop, hopeful it works.
May 30, 2020 at 12:55 am
FMS20
SubscriberSo Ill put QT_OPENGL=desktop as the value, does it matter what I put as the variable name?
June 1, 2020 at 12:05 pm
Hunter Wang
Ansys Employeevariable name: QT_OPENGL
variable value: desktop
June 1, 2020 at 3:23 pm
FMS20
SubscriberThe environment variable did not make any difference for Fluent or CFX.
What exactly is the nature of the application not connecting at this particular point (Solution for Fluent and Setup for CFX)?
Is there an older version of this program that I might try as well?
June 1, 2020 at 3:41 pm
Hunter Wang
Ansys Employeemake sure QT_OPENGL=desktop is set, try to open standalone CFD-Post 2020 R1 (Start > ANSYS 2020 R1 > CFD-Post 2020 R1)
June 1, 2020 at 4:36 pm
FMS20
SubscriberYes, the system variable is set.
I do not see a 'CFD-Post 2020 R1' in that location or anywhere else.
June 1, 2020 at 5:46 pm
Hunter Wang
Ansys Employeecheck ANSYS installation log and error, in "C:Program FilesANSYS Inc" by default.
June 2, 2020 at 3:12 am
FMS20
SubscriberIt looks like the issue has been resolved:
I checked in the ANSYS Inc folder, and eventually found a CFDpost.exe. When I tried to open it, it said that vcruntime140.dll was missing. I eventually reinstalled Microsoft Visual C++, went back to Fluent, and was able to open Setup.
There were no error logs - I'm not sure how that dll file was missed. But Fluent seems to be working now.
Thanks for the assistance.
June 2, 2020 at 1:02 pm
Hunter Wang
Ansys EmployeeGood to know. The original issue is "keep getting an 'Application failed to connect' message when trying to open 'Results'."
Assuming this issue has been resolved as well?Â
June 2, 2020 at 3:49 pm
FMS20
SubscriberYes, I meant to say that I can open Results in Fluent now.
The original issue is resolved.
June 2, 2020 at 9:05 pm
Hunter Wang
Ansys Employeegood to know
September 25, 2023 at 10:02 am
Cuong Nguyen Van
SubscriberI can't result after solution in workbench because it gives an error: application failed to connect
what do I do now?
- The topic ‘Application failed to connect’ is closed to new replies.
5939
1307
