December 5, 2024 at 6:59 pm
December 9, 2024 at 9:34 am
NickFL
SubscriberÂ
It seem you have installed an Add-on that uses an old API. If you are not using the Add-on anymore it won’t be a problem, they are just giving you a warning that it will not work next release. If you do use the Add-on, you may need to re-write parts of it to work in the new API (although many simple tasks will looks the same).Â
After a second look, you may be using the ANSYS provided Add-in Sample. There is a new version written in API24 that you can use instead.Â
1891
1419
