October 20, 2019 at 8:27 pm
ankitdv98
SubscriberHey guys!!!
How different is workbench from APDL? is there much difference in results or analysis? which one do you guys recommend??
please share your experience as i have to decide what solver should i use for FEA including rotodynamic analysis?
October 21, 2019 at 2:23 am
peteroznewman
SubscriberWorkbench and APDL use the same solver. The difference is the user interface to build the model and review the results.
I recommend Workbench because I find it is easier to use. Â
October 21, 2019 at 3:11 am
sathya
SubscriberHi,If you are strong in FEA flow-process and love to work step by step traditional approach go with APDL.
If you are relatively new to simulation tools & want to get straight to work prefer WB.Â
October 27, 2019 at 7:37 am
ankitdv98
SubscriberThank you guys, but are these two going to give exact same results??
October 27, 2019 at 9:20 pm
peteroznewman
SubscriberYes, they use the same solver so will give the exact same result. It is just the user interface to build models and look at results.
- The topic ‘APDL vs WORKBENCH’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3977
1461
1272
1124
