October 24, 2021 at 11:52 pm
GT1987
SubscriberI am currently working with a large model in APDL that I am trying to modify by creating moment releases between certain regions at intersections where SHELL181 elements meet. The only ways that I know of simulating this is the following:
- Create links via beam elements between the shell elements and release rotations within the beam element. Shell elements do not share nodes at locations where the beam elements are being used.
- Use the coupled nodes option "CP" at the interface where hinge is desired but requires that elements at the interface not share nodes.
Is there an alternative way to simulate moment releases with shell181 elements at locations where elements share common nodes? Additionally, Assigning membrane option (keyopt(1) = 1) only for shell181 elements at desired location of hinge does not work very well.
My text for the test model is attached below:
October 27, 2021 at 5:57 pmdlooman
Ansys EmployeeThere is nothing analogous to the ENDRELEASE command for shells. The CP method that you propose seems to be the best way.
Viewing 1 reply thread- The topic ‘APDL Shell181 to Shell181 Moment Release (Create Hinge) at Location of Shared nodes?’ is closed to new replies.
