APDL Output Error: Load Set Not Found on Results File
    • ebone2god
      I'm having an issue running a simulation in APDL. I am reading an input from a .txt file to run a quasi-static simulation named "AllRuns" and output the results to a new .txt file. When the solution completes and tries to write the outputs to a text file, I get an error message stating:
      "Load Set not found on results file AllRuns.rst"
      I'm following the same steps as I followed a few days ago to run this simulation, but this is the first time I have seen this error and I can't seem to solve it. Has anybody encountered this issue before? I would appreciate any suggestions on how to fix this problem.
      Best regards,
      Eoghan
    • Vitaliy_Degtyarev
      Eoghan,
      Do you use outres,all,all? It should solve the issue.
      Vitaliy
    • ebone2god
      Hi Vitaliy,
      That did the trick - thanks! I previously had:
      outres,all,(total number of load steps)
      Not sure why it started causing issues all of a sudden, but switching the number of load steps to "all" fixed everything. Thanks again!
    • jaimin9777
      I did beam analysis with apdl student version software. The solution is already solved but I can’t read results files (which is in frequency of beam analysis). I can’t read results files as it is shown in my photos that such error is occurring “no results on file”
  • The topic ‘APDL Output Error: Load Set Not Found on Results File’ is closed to new replies.
