April 7, 2024 at 9:02 am
s300677
SubscriberGood morning,
I'm studying the transient behaviour of a structure with U-flipped shape. As input I excite the structure with a sine signal produced with matlab and I applied it to the two nodes at the base: the file is a table with two columns (one for the time and the other for the displacement) and a number of rows depending on the sampling frequency. To import the file I use *DIM and *TREAD. Even though it's seems correct to me, the displacement field is applied to only one node of the two selected. What can the error be?Â
May 16, 2024 at 11:24 am
Ashish Khemka
Forum ModeratorHi,
Can you please share the command you have used to select the nodes and apply the displacement?
Ashish Khemka
- The topic ‘Apdl mechanical’ is closed to new replies.
Ansys Innovation Space
1007
923
858
792
