August 28, 2020 at 12:24 am
helen.durand
SubscriberHello!
I am currently running a simulation in transient thermal in Workbench, and have added an APDL command object to modify the solution. I have it set so that the commands are ran for every load step.
I want to be able to, at each load step, get the temperature at nodes so that I can modify what occurs the the next load step. However, I have been unable to get any of the commands to work during the solution processor. Below, I have included a snips of the commands I have tried and the outputs that appear is the solution information. It appears that either the commands are not defined properly or that the value is not available.
What can I do to be able to pull temperature data between load steps during the solution processor?
Thank you!
A command object has been inserted to modify the solution processor:
August 28, 2020 at 12:53 pmAshish Khemka
Forum ModeratornnYou can insert this command object in the Solution and then try to restart the solution.nn/forum/discussion/6624/restart-analysisnnRegards,nAshish KhemkanViewing 1 reply thread- The topic ‘APDL: Getting node temperature information between load steps during solution’ is closed to new replies.
5574
1885
1403
1298
