APDL command to reduce .rst size
    • vera-lise.schmitt
      I am looking for an APDL command which reduce .rst size saving only stresses on the skin of a component.
      Indeed, I am working on harmonic responses and the size of the .rst is to important for my cluster.
      Thank you in advance
    • Saumadeep Choudhury
      Hi Veral,
      You can use the OUTRES Command. It controls the solution-result data written to the database.
      Please see this Ansys Help Link: OUTRES (ansys.com)
      Saumadeep Choudhury
  • The topic ‘APDL command to reduce .rst size’ is closed to new replies.
