APDL Command to Export Specific Nodal Stress Values
    • james.lee
      Apologies if this is the incorrect area to post the following, this is my first post.
      I would like to export an array of nodal principal stress values to a text file and have created the following APDL command to do so:
      The problem is my output file contains values that do not reflect those in the relevant contour plots and associated exported text files:
      I have tried several options with the *VGET and *GET commands to no avail. Could someone point ime in the right direction as I am not overly familiar with APDL command references.
    • ErKo
      Hi
      These example shows some different ways of doing this.
      https://www.ansystips.com/2017/10/ansys-apdl-some-neat-commands.html
      All the best
      Erik
      • james.lee
        Thank you Erik, much appreciated.
    • Sai Deogekar
      Based on Table 244 in in this Ansys Help link: *VGET you can see that when using Item1=S, ENTNUM has to be a node number. I am not sure what happens when it is left empty. My guess is that it defaults to node 1 and it keeps looping till the array 'Principal' is filled up. Could you check if the values printed in FLS1_1.txt match with the principal stress values for node 1 to 4?
      • james.lee
        Hi, you are correct, the stress values reported appear to be associated with node 1 to 4. Is it possible to associate the selected nodes with the VGET command? I have updated the script to reflect the nodes selected but am only able to output zero values in the text file:
        Your assistance is much appreciated.
    • Sai Deogekar
      Maybe you can try looping over the selected set of nodes using the *DO command and use *GET command to retrieve the principal stress values for each node in the set.
      ! Loop over selected nodes
      *DO, i, 1, numNd
      *GET, nnum, NODE, 0, NXTH ! Get the next node number
      ! Perform operations on the node
      *ENDDO
