October 14, 2024 at 5:17 pm
October 15, 2024 at 8:54 am
mohan.urs
Ansys EmployeeHey,
Could you please provide more info into what you are doing like BCs or the APDL code ?
Maybe we can figure out the why from the loads and setup.Thanks
October 18, 2024 at 6:03 pm
hasanilkerceliker
SubscriberI am using apdl code. it does not start where I defined the coordinate system
October 18, 2024 at 6:07 pm
hasanilkerceliker
SubscriberI defined the top region as base and the bottom region as body. I separated them as node and element. I selected these regions with cmsel code and used cmsel,u code for other regions.Â
1306
