March 4, 2021 at 3:55 pmyfeng4 SubscriberDear All,nI want to ask if anybody knows a good tutorial on installing visual studio for Fluent UDF compiling. For example which version of the VS, and any additional steps need to be taken to make it work? nThank you very much.l n
March 4, 2021 at 4:05 pmYasserSelima SubscriberYou don't have to. The built in compiler in Fluent 2019 and later can compile your UDF. Write the UDF in a text editor and save it with extension .c in the same directory with fluent case file. nWhen compiling, check the box, use built in compiler before pressing buildn
March 19, 2021 at 9:21 pmyfeng4 SubscriberThank you so much for your help! n
March 20, 2021 at 6:05 amYasserSelima SubscriberYou are welcome!n
- The topic ‘Anybody knows good tutorial on installing visual studio for Fluent UDF compiling’ is closed to new replies.
- affinity not set
                        1487
                        1363
                        1194
     You are navigating away from the AIS Discovery experience
