February 8, 2024 at 7:08 am
smani
SubscriberHi,Â
Where will I get to know the various quantities and their definitions used in HFSS software.
Particularly, I am interested in the following question:
What does "rEPhi" and "rETheta" represent. and, when we get rEphi in dB, does it mean 20log10(mag(rEPhi)) or 10log10(mag(rEPhi)).
February 9, 2024 at 6:27 am
Praneeth
Ansys EmployeeHi,
Please go through "Selecting a Far-Field Quantity to Plot " section of the HFSS help document available through the Help menu.
Best regards,
Praneeth.
- The topic ‘Antenna quantities definition and operations in HFSS software’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1256
1118
1015
