Electronics
Electronics
Antenna Array
    • andreev
      I have created an antenna array (4 radiators) and calculated an radiation pattern of that array. However, the calculated radiation pattern looks like a radiation pattern produced by a single antenna, not an array of four antennae. So, I wonder, what is wrong with my simulations? The input file is attached.
      Thanks!
    • andreev
    • Sorceress Gia
      Check the Source Excitation Settings found under "HFSS > Fields > Edit Sources". By default only the first port is excited.
    • andreev
      Peter, thank you!
      It works!
    • Sorceress Gia
      You're welcome! Can you please 'like' and tag my post as the answer to your question? Thanks!
Viewing 4 reply threads
  • The topic ‘Antenna Array’ is closed to new replies.
