July 16, 2020 at 5:15 pm
KoenFranse
SubscriberHello,
I've been working with Ansys Workbench, Mechanical and Fluent for two weeks now and had no problems until today. When I opened Workbench, created a new Transient Structural window and tried to create a new DesignModeler geometry, DesignModeler didn't open correctly and gave me the error: "AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpfile.dmp". This strange since up until today this worked perfectly. Furthermore, if I want to edit a model in Mechanical, it doesn't start correctly and I only get a grey screen. I already tried various solutions I found on other pages, but nothing seems to work. I also reinstalled all Ansys products. Can you help me to fix this?
Thanks, Koen
July 17, 2020 at 8:07 am
KoenFranse
SubscriberI finally fixed it, the instructions in the link below helped me out:Â
July 21, 2020 at 9:08 pm
tsiriaks
Ansys Employee Great to hear. Thank you for searching the past posts.
October 21, 2020 at 3:51 pm
azaanahmad234
SubscriberHello ANSYS users! I am trying to analyze beam related problem, but whenever I double click the MODEL to open what I have drawn in Design Modeler it pops up an error which says "AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpfile.dmp". I have re-installed ANSYS and also change the path to drive C, still the problem persists. Please help me to get out of this problem.
Thanks in advance!
February 28, 2021 at 5:38 pm
Pushkin
Subscriber"AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpfile.dmp".
I finally arrived at a solution for this problem after 7 times re-installing Ansys.
Solution:
Just click start >> type workbench >> right click then open file location >> it will be stored in C drive.
Cut Ansys folder
And paste in the drive where you installed your software. If D drive suppose, paste it in drive
February 28, 2021 at 5:43 pm
Pushkin
SubscriberIf u follow above steps then you may not arrive at the same problem again.
Hope it helped.
Happy learning
March 1, 2021 at 11:25 am
Bally
SubscriberI have the same problem up to now, Though I initially installed the software on Drive which was the default suggested drive for me while installing. Please any other way to help out solve this problem
April 29, 2021 at 7:05 am
April 29, 2021 at 7:21 am
August 3, 2021 at 3:16 pm
Hugh
Subscriber.This link doesn't work as it has been closed. Can the forum managers please open this link again, so we can understand what needs to be done: /forum/forums/topic/getting-error-ansyswbu-exe-encountered-a-problem/?order=all#comment-8c46e9a5-2cff-4c83-8929-aac000247f62
August 9, 2021 at 10:35 am
Shrey_B
Subscriber.Hello,
This link doesn't work (/forum/forums/topic/getting-error-ansyswbu-exe-encountered-a-problem/?order=all#comment-8c46e9a5-2cff-4c83-8929-aac000247f62).
Could someone please help to solve this problem "AnsysWBU.exe encountered a problem. A diagnostic file has been written: C:UsersusernameAppDataLocalTempAnsysWBDumpfile.dmp".
I tried all the above suggested ways but still the problem persists.
Thank you
September 22, 2021 at 12:43 pm
November 11, 2021 at 10:53 am
November 17, 2021 at 12:00 am
yasker
Subscriber.I had the same problem. I have tried all the ways above but nothing works and I need to resolve this urgently. Can anyone help please?
March 28, 2022 at 12:40 pm
- The topic ‘AnsysWBU.exe encountered a problem. A diagnostic file has been written’ is closed to new replies.
5084
1823
1387
1248
