TAGGED: #mechanical-#workbench, ansys-error, mechanical
April 9, 2024 at 8:23 am
260094
SubscriberHi.Â
I've been having the same problem for the past month on my Windows 11 PC. I use a Intel i5 core and use a Nvidia GEFORCE GTX graphics card.
I'm currently on 2024R1 version.Â
I have tried everything from another thread, some of which includes;
- reinstalling Ansys Workbench (both 2023 and 2024 version)
- changing the name of the appdata folder to "_old"Â
- In the the Design Modeler < tools < options < Mechanical < Analysis Settings and Solutions < Analysis Data Management < Scratch Solver Files Directory < specifying a folder for scratch
I am able to open projects and import files into 'static structural', but then I'm shut off from doing anything else.
This message pops up every time I try to generate an imported file into the design modeler (from static structural). Any imported file wont generate and the Design Modeler closes.
Any suggestions?
April 10, 2024 at 1:31 pm
Gary_S
Ansys EmployeeIs this a Notebook computer?
Please run DxDiag.exe, Save All Infomation, then copy pasts ONLY the following lines in your reply.Â
EXAMPLE:Â
Display Devices
   Card name: NVIDIA RTX A4000
   Manufacturer: NVIDIA
   Driver File Version: 31.00.0015.5186 (English)
   Driver Version: 31.0.15.5186 -
April 15, 2024 at 11:08 am
260094
SubscriberHi Gary.
Yes, it is a laptop.Â
This is what I got:
Display Devices
      Card name: Intel(R) UHD Graphics 630
    Manufacturer: Intel Corporation
Driver File Version: 27.20.0100.8729 (English)
   Driver Version: 27.20.100.8729*Second GPU*
Card name: NVIDIA GeForce GTX 1660 Ti
    Manufacturer: NVIDIADriver File Version: 27.21.0014.5749 (English)
   Driver Version: 27.21.14.5749Â
April 15, 2024 at 12:36 pm
Gary_S
Ansys EmployeeÂSome computers have 2 graphics processors, often one is "Intel" and the other is an "nVidia"
 We need to set the nVidia to be the "preferred" graphics adapter
See if you can find "nVidia" control panel.  Control Panel > nVidia control Panel > go to 3D settings > Manage 3D settings > Under Preferred Graphics Processor > choose nVidia > Apply.
Â-----------------------
Go to the Nvidia website and download the latest driver for the GeForce GTX 1660 Ti
April 16, 2024 at 11:10 am
260094
SubscriberHi Gary.
I've applied the nvidia GPU as the preffered one on the control panel. The driver was the latest one available.
I rebooted the computer and tried again, but the problem still persists.
April 16, 2024 at 3:07 pm
Gary_S
Ansys EmployeeHi Patrick
Duplicate the crashÂ
Run Windows System Information..
 in: Windows Error Reporting
 For easier searching, save the Error list as a text file with File > Export
 Search the list for the name of the DM executable (AnsysWBU.exe)Â
 ...I am interested in the corresponding Faulting Module Name ÂÂ
April 18, 2024 at 1:12 pm
260094
SubscriberHi Gary.
This is what I got:
18-04-2024 12:34   Application Error   Navn på program med fejl: AnsysWBU.exe, version: 24.2023.331.1, tidsstempel: 0x6564cee6 Navn på modul med fejl: psxlatorbase.dll, version: 21.0.47.0, tidsstempel: 0x59d53e56 Undtagelseskode: 0xc000041d Forskydning med fejl 0x000000000005cb1c Proces-id 0x0x5E44 Programmets starttidspunkt 0x0x1DA918CC1B83905 Programsti: C:\Program Files\ANSYS Inc\v241\aisol\bin\winx64\AnsysWBU.exe Modulsti: C:\Program Files\ANSYS Inc\v241\AISOL\CADIntegration\Parasolid\winx64\psxlatorbase.dll Rapport-id: 81c3e72e-2f17-4ea6-a011-8f325bf73308 Fuldt navn på program med fejl: Relativt program-id for program med fejl:
April 18, 2024 at 1:21 pm
Gary_S
Ansys Employeepsxlatorbase.dll is the Parasolid library module. It not common to see a crash in this module.Â
Are you able to import a simple file like IGES or Parasolid into DM and edit?
There are samples here: C:\Program Files\ANSYS Inc\v241\ansys\ac4\examples\ -
April 18, 2024 at 1:46 pm
260094
SubscriberHi Gary.
I tried one from the examples list (< examples < para < torsionbar.xmt_txt) and I'm able to generate in DM and load the model into mechanical and solve for various.Â
April 18, 2024 at 1:57 pm
Gary_S
Ansys EmployeeOk. It seems the problem is with your actual model, or with your workflow.Â
Can you elaborate on:
"This message pops up every time I try to generate an imported file into the design modeler (from static structural). Any imported file wont generate and the Design Modeler closes.
- The topic ‘AnsysWBU.exe encountered a problem…’ is closed to new replies.
5814
