June 24, 2023 at 3:16 am
mgarciaruiz
SubscriberWhenever I close mechanical It crashes and produce a core dumped.
Also When I create a fluent project from within workbech It produces a Warning:
"Software rasterizer found, hardware acceleration will be disabled.
In the absence of hardware-accelerated drivers, the performance of all graphics operations will be severely affected...." and it is not able to load the geometry or the mesh. however if I run Fluent directly and load a case, it is able to solve with no problem.I checked all prerequisite libraries and nvidia drivers and seem to be ok
Any help will be apreciated
MG
July 6, 2023 at 5:40 pm
George Karnos
Ansys EmployeeRecommend to check the Graphics Card is it supported and is the driver up to date.
Also, verify that all prerequisite libraries that are listed in the Installation guide are installed and the
Linux make and version is supported. -
July 7, 2023 at 3:03 pm
mgarciaruiz
SubscriberThanks for the answer.
The OS is  Ubuntu 20.04.6 LTS. Supported.
The graphics card is an Nvidia RTX A4000 which is supported (However, The website says it hasn't been tested in Ubuntu)This is what I have done so far.
Checked all dependency libraries and install the missing ones.
Check the Nvidia Drivers
Reinstalled Ansys.
changed the symbolic link of libstdc++.so.6 in the fluent folder to the installed by Ubuntu.ÂNow fluent run if it is launch standalone  butÂ
 I still have the problems:
   Structural module: Mechanical aborted with a core dumpedÂ
   Fluent: Fluent doesn't run properly from within Workbench. Produced the error reported in the original message
- The topic ‘AnsysWBU.exe crash when mechanical is closed in Ubuntu’ is closed to new replies.
5809
