February 19, 2018 at 1:58 pm
Student_One
SubscriberHello Community,Â
I am an Ansys Workbench beginner. How do I change the stress results legend from pa to MPa ?
February 19, 2018 at 3:54 pm
peteroznewman
SubscriberClick on the Units menu and select mm and the stress will be in MPa.
February 26, 2018 at 3:53 pm
Student_One
SubscriberThank you!
October 10, 2021 at 7:12 am
Vivjk94
Subscriber.Sometimes even though you change units in options, it wont readily reflect in legend. If that happens then you can go to edit>options>units> in system drop down menu you can select any other unit system ie. english engineering/British technical etc and click apply and then select the preferred unit system and click apply. That way the legend unit will get refreshed and will show the unit you want. I think its kind of a bug but here is the workaround.
Cheers,
Vivek
- The topic ‘Ansys Workbench Results Legend’ is closed to new replies.
Ansys Innovation Space
1263
1107
1068
953
