July 23, 2023 at 7:13 pm
Aaron Johnson
SubscriberI am trying to run a topology optimization for a part, however I keep getting the following message."the optimization solution run was terminated. check the solver output on the solution information object for possible causes"I then open the "Open Solver File Directory" to view if I am getting any error files or issues.I have a topo.err file that says the following.*** WARNING *** The optimization problem cannot be solved. Please reformulate your problem. *** ERROR *** MAPDL solver terminated unexpectedly with error code 99. For more information check solver output. *** WARNING *** File 'numCPU.dat' not found.Below is the topo.out file. ---------------------------------------------------------------------- ----------     Welcome to Topology Optimizer     ----------- ----------------------------------------------------------------------    Version 2022 R2 (Build: 194) from 20220527    Copyright 2022 ANSYS Inc. All Rights Reserved ----------------------------------------------------------------------    Execution time: Sun Jul 23 13:45:59 2023 ----------------------------------------------------------------------  Parameter setting:   solver          = Scpip   ansys version      = 2022 R2   design elements     = OptimizationRegionElements.dat   feedersystem list:    - Static system 'Static25' with id 25: 1 load case(s) at t = 1   filter mode       = 1   penalty parameter    = 3   minimum member size   = 0   maximum member size   = 0   minimum density     = 0.001   initial response scaling = yes   boundary padding     = true,bounds,vol   restart information   = final   mapdl ncnv        = 1e+12   maximum iteration    = 500   acc           = 0.001   units          = MPA   output frequency     = 1   max intermediate files  = 500   dynamic max approach   = true, 0.9   objective 1       = single compliance (force load) for load step 1 of feeder system 'Static25' [1]   constraint 1       = total mass with lower bound 60 and upper bound 60   constraint 2       = global equivalent (von-Mises) stress for load step number 1 of feeder system 'Static25' with upper bound 227.273   method          = SCP   acc scp         = 1e-06   version scp       = 402   cut off in scp      = 1   linear inequalities remain in active set in scp = selected always   initial penalty scp   = 1   move limit scp      = 0.5   asymptote strategy    = program controlled ----------------------------------------------------------------------  Start generating constant data...  ...done  Start generating tree...  ...finished.  Start generating element neighborhood...  10 Percent done  20 Percent done  30 Percent done  40 Percent done  50 Percent done  60 Percent done  70 Percent done  80 Percent done  90 Percent done  100 Percent done  ...finished. Determine regions where minimum member size cannot be satisfied.  Starting MAPDL... *** WARNING *** The optimization problem cannot be solved. Please reformulate your problem. *** ERROR *** MAPDL solver terminated unexpectedly with error code 99. For more information check solver output. FINAL SUMMARY ------------- Total number of model evaluations: 0 Objective(s):  [ 1] Name: Objective     Value : 1.79769e+308 Constraint(s):  [ 1] Name: Mass Constraint_64     LB: 6.00000e+01 <= Value: 1.79769e+308 <= UB: 6.00000e+01 Deviation: inf %  [ 2] Name: Global Stress Constraint_71               Value: 1.79769e+308 <= UB: 2.27273e+02 Deviation: 7.90985e+307 % NOTE: This is an approximation to the actual value: 0. *** WARNING *** File 'numCPU.dat' not found. ---------------------------------------------------------------------- --> Topology Optimizer finished with errors   Total time: 0h 2m 1s   CPU time:  0h 0m 0s   Peak Memory: 172968 K   I/O Read:  48568849 Bytes   I/O Write:  928365 Bytes ----------------------------------------------------------------------Below is the solve.out file. *** FATAL *** Attempt to run ANSYS in a distributed mode failed. The Distributed ANSYS process with MPI Rank ID =   1 is not responding. Please refer to the Distributed ANSYS Guide for detailed setup and configuration information.I have looked at some other forums, but I can't seem to figure out the issue.I don't know if I need to change someting in the "Advanced Properties" in the "Solve Process Settings". -
July 24, 2023 at 11:26 am
Lydia Lymperopoulou
Ansys EmployeeHi Aaron,
Are you sure you are correctly modeling your problem? I suggest you follow the steps demostrated in this course Topology Optimization in Ansys Mechanical | Ansys Innovation Courses
July 24, 2023 at 1:46 pm
Aaron Johnson
SubscriberThank you for the response. I ran the Ansys innovation courses file you suggested and ran into a similar problem. I generated the same error message.
"The optimization solution run was terminated. check the solver output on the solution information object for possible causes"
Association: Project>Model>Topoogy Optimization>Solution
It gave me an topo.err file, but nothing was in it. It also gave me a solve.out file that says the following.
 *** FATAL ***
 Please refer to the Distributed ANSYS Guide for detailed setup and configuration information.Â
The only thing that I could not do was to make sure to turn on "level set method topology optimization" as it was not in my options.
The file that I'm trying to recreat is in the following video as it is for my class. ANSYS 18.1 Topology Optimization - YouTube
July 24, 2023 at 12:38 pm
John Doyle
Ansys Employee-
July 24, 2023 at 1:48 pm
Aaron Johnson
SubscriberI tried to do the Ansys Innovation Course above and I did not get the system to work again. This is my first time running the topology Optimization. I have tried a few difference test problems, but I get similar results.
September 7, 2023 at 11:03 am
Daniel Lim
SubscriberI am experiencing the same error as Aaron with the objective value stating the same value: 1.79769e+308. Is there an update to this issue?
- The topic ‘ANSYS Workbench – Mechanical – Topology Optimization – MAPDL Error’ is closed to new replies.
5784
