February 5, 2021 at 1:52 pm
s213bell
SubscriberHello,nnWe are using ansys 2021r1 and when we try to upload .cas.h5 files it loads for a second then we get a popup that says ansys workbench has stopped working. How can we resolve this crashing when trying to upload a file.n -
February 5, 2021 at 3:35 pm
Forum ModeratorAre there any errors reported in Fluent? n -
February 5, 2021 at 3:45 pm
s213bell
Subscriberwe just get a popup that says ansys workbench has stopped working. A problem caused the program to stop working correctly windows will close the program.n -
February 5, 2021 at 3:50 pm
Forum ModeratorAnd if you open Fluent and try to read in the file? n -
February 6, 2021 at 12:33 am
YasserSelima
SubscriberThis happened with me before and I found that the issue was a UDF that I hooked on reading the file. The problem was solved by removing the udflib folder and removing the source code from its location. And the case was loaded successfully with error of not finding the library. nIf you are using UDF, delete the folder and change the source code directory and try again. n -
February 8, 2021 at 2:25 pm
s213bell
SubscriberClient said I usually open up Fluent > Set up > File > Import > Case&Data is that what you mean Arrayn -
February 8, 2021 at 2:27 pm
s213bell
SubscriberI am not sure what udf is but i looked through the installation directory and couldn't really find anything. Where would it be?n -
February 8, 2021 at 2:34 pm
s213bell
SubscriberI found the udf folder but can't find a udflib folder. I have asked the client if this is something they use.n -
February 8, 2021 at 2:50 pm
Forum ModeratorThe UDF would be a libudf (default name) in the same folder as the case and data files. Can you ask your user to open Fluent from the Start menu? If there is no icon they need the fluent.exe file that's in nC:\Program Files\ANSYS Inc\v211\fluenttbin\win64\fluent.exenassuming they didn't do anything clever during installation. Is the file that's failing from 2021R1 or an earlier release? n -
February 8, 2021 at 2:59 pm
s213bell
SubscriberI have asked what release the file is from. I am guessing it is from an earlier release since they have been working on this project for awhile but I will clarify. When opening fluent directly and opening the file this is the error. Unable to open | utility fl42seg X:/UNC_003NC_PrismMesh_4Mcells.cas.h5 for reading.: iostream stream errorn -
February 8, 2021 at 4:01 pm
Forum ModeratorThat may be more useful. Is the X: drive local or network/USB drive?n -
February 8, 2021 at 4:03 pm
s213bell
SubscriberIt is a network drive. All users use the network drive as we restrict them from using the cdrive on the machines.n -
February 8, 2021 at 4:10 pm
Forum ModeratorNetwork drive on Windows I take it. I wonder if it's latency/packet loss related then. We see this every few years as the cases get bigger and drive/network speeds increase: depending which is the winner the model may or may not load. Will smaller files load OK?. -
February 8, 2021 at 4:13 pm
s213bell
SubscriberIt is a very small file listed at 0kbn -
s213bell
Subscriberand we have other users uploading bigger files. It is just ones that are .cas.h5 that aren't working it seems.n -
February 8, 2021 at 4:15 pm
s213bell
SubscriberI also just tried uploading the file from the desktop and same errorn -
February 8, 2021 at 4:50 pm
YasserSelima
Subscriber0 kb .. so probably the file is corrupted n
Viewing 16 reply threads
- The topic ‘Ansys Workbench crashes when trying to upload .cas.h5’ is closed to new replies.
1307
