3D Design
3D Design
Ansys Workbench–Boolean issue
    • 2375423
      Dear all, here is the error which I have got from Ansys Workbench, and I wants to make the mesh around the turbine blade, and you can test it by using the attached test model.
      The steps for me to use Ansys-workbench Geometry is:
      1. Drag ‘Geometry’ from Component Systems in the left sides to the project schematic window;
      2. Right click the 2. ‘Geometry’, chose ‘New DesignModeler Geometry’;
      3. File—Import External Geometry File—Chose the attached model—Generate;
      4. Tool-Enclosure-set up as the default if fine—Generate;
      5. Create-Boolean—Operation: substract—Target Bodies: click the box created at Enclosure in Step 4 (which you can chose from ‘2 parts, 2 bodies—solid&rsquo, apply—Tool Bodies: click blade model (which you can chose from ‘2 parts, 2 bodies—1D3D&rsquo, apply—Generate
      Then most wired thing is, I have run it in my laptop and it is sucess. However, when I try to run it in my PC, then it failed (red exclamation mark in the front of Boolean1). Both computer are use Windows 10 system.
      If you have any comments or sugguestions to runs this boolean sucessfully, please let me know, thank you.
Viewing 0 reply threads
  • The topic ‘Ansys Workbench–Boolean issue’ is closed to new replies.
